clear cdp neighbor
clear cdp neighbor [device id device_id | all]
Description
Clears the CDP neighbor information.
Syntax Description
device id Specifies the Device Identifier to be used in CDP.
device_id Specifies the Device Identifier of neighbor.
all Specifies all CDP neighbors.
Default
N/A.
Usage Guidelines
Use this command to clear the CDP neighbor information.
The following command clears all CDP neighbor associations:
clear cdp neighbor all
This command was first available in ExtremeXOS 15.4.
Platform Availability
